I've got a customer who wants an outside light removing and a replacement installing about 4 metres away on the same wall. The location where she wants the new light happens to be directly behind the relevant lightswitch.
Is it acceptable to do the following?:
1. Remove existing light.
2. Crimp the N to the S/L at the existing light and poke it back through the wall. This will mean that, at the lightswitch, the wires which were previously L and S/L are now permanent L and N.
3. Now that I have a permanent L and N at the lightswitch, connect a short length of wire and run it through the wall behind the lightswitch to give me power for the new light, with another short length back through the wall to give me a new L and S/L.
Obviously I would only do this if the cable tested out ok, and if I could leave it in such a way that it complied with the regs (in safe zones, etc).
The advantage would be that I avoid running a new cable along the outside of the house.
Thanks in anticipation!
