Discuss Underground/buried connection in the UK Electrical Forum area at ElectriciansForums.net
Hello all
I have been called out to quote for a garden job where the builder has run a 6mm armoured cable out to the garden, it's not long enough for it's final destination though and so I want to connect onto it, extend it and bury it. Never having buried an outside joint before what is a good product for the job? I see there are a variety of epoxy resin options but I can't seem to find one that I can easily maintain the armour's continuity.
Any suggestions much appreciated
Every resin cast joint I have ever done has come with braided earthing strap and constant pressure springs to link across the armourings.
Last few torpedo's resin joints I've had have had a jubilee clip and a metal ring (olive?) and braided earthing strap, and either choc blocs or through crimps. Still find the idea of using the choc blocs worrying so I'd use Wago's instead.
never underestimate the value of a jubileel clip!
It is your friend in many circumstances!
However, i wouldn't advocate them as ideal for cpc continuity cos i would get slagged off endlessly!
They also make novel napkin rings and can be used as an aid to premature....no, forget that...I'll get my coat!
Did one last week on 6mm 2core swa, builder had stuck the digger through it, it came with those constant force springs and strap, but I also kept a few strands of the armour long from each side and put in a couple of connectors aswell (kit came with 4)
I don't trust those spring/braid thingies. On small SWA's like the OP's 6.0mm I leave the steel long and join ALL the strands either in a 60a connector or a line tap. I don't trust Pratley boxes either. Had to dig up quite a few over the years where water has got in. Resin joints done correctly will never fail.
The Birkett ones seem to get good thing said about them:
They have the constant-force springs for CPC continuity (as mentioned by Andy78) and once filled with resin ought to be as good a seal as you can get. But I would read the instructions twice and follow them carefully!
[automerge]1591431161[/automerge]
At least at this time of year you ought not to have any issues with the mixing / viscosity / curing of the resin filler.
One thing that I don't get with these, and I've used a few....,
Regs say that screw terminations should remain accessible. Most of these kits use screw terminal connectors and are certainly not accessible, being encased in resin and buried half a metre down!
As far as I know the regs don't make any specific mention of screw connections being accessible. In fact 526.3 points out that a joint designed for burial need not be accessible.
[automerge]1591438242[/automerge]
I know what you mean about the earthing springs. I have always wrapped them tight then tightly covered over with SA tape in the direction of spring coil to hold them fast while the resin is poured. Once the resin is in and set I have no worries about the connection.
Reply to Underground/buried connection in the UK Electrical Forum area at ElectriciansForums.net
My garden lighting was tripping my MCB so I checked all the junction boxes outside. I disconnected the live, neutral and earth connections in...
Just after some general advice. Been asked to look at a job where a builder/landscaper has already laid cable for some garden lighting.1.5mm 3...
Afternoon everyone.. During some testing I have found an IR reading of 0.01MΩ between N-E. This is on a length of SWA buried underground from the...
Hi, I'm looking for some advice. We are a garden irrigation company and I have an electrical background (up to 16th edition). We're carrying out...
