Discuss Unsleeved plug tops in the Canada area at ElectriciansForums.net
Yes, the pins of a plug now have to be sleeved approx half their length so that when you withdraw plug and accidently touch them you can't get a shock, as they will not be in contact with socket connections.
I believe this has been the case now for over 5 years at least.
erm....no
any NEW plugtops must be sleeved, but there is no requirement to remove old (perfectly serviceable) unsleeved plugtops
Reply to Unsleeved plug tops in the Canada area at ElectriciansForums.net
I saw a Fluke 1653B on Gumtree local to me being sold as faulty. Fault was stated as no continuity between 'N' and 'PE' ports on the resistance...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Private tenant since 2011. First ever eicr February 23 informed via text it failed by text from electric secretary arranging appointment for...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
