M
MTI
hi all, been asked to do various works within an office which is part of a multi-story. Please can anyone advise on the following questions? i do have my own judgements but would like to see what you all come back with. This will also help my confidence in what i have told the client. Thanks in advance!
1) open plan office existing m/c c.u. is full and new circuits are required. The new loads are not expected to be massively high. Would you change existing board (10 way) to accomodate new circuits or will i get away with a second c.u.? Hoping to keep costs down and minimal disruption and not have to replace existing m/c c.u. as it serves computer servers etc currently.
2) If second c.u. is fitted, should i remove and extend a lighting circuit/air con unit into new board and feed new board from existing newly made spare way?
3) existing board is m/c and fed via s.w.a. sub from basement. if feeding new board off existing board spare way, what size breaker, tails and incomer on new board?
Dont want to have leave client with a very small incomer on new board really, although new loads not massive but could be added to later obviously.
4)patch panel cabinet-can anyone advise of a 'typical' load? may sound daft but premises is empty and not accessable for a few days now and would help for sizing new s.w.a. feed to it. surely it wont be massive load? cabinet is approx a 2m cube and approx 1 meter high if this helps.
5) will patch panel earthing be o.k. if fed by seperate earth from new c.u.? currently not earthed but obviously wants it if serving IT equip. what size earth too please....10mm or 16mm?
6) am i ok to use top and bottom of 3 compartment dado for cat 6? both empty and dont see why not. phones will be over IP too. also, how many data cables will fit comfortably in each compartment taking into account internal and external bends? ill have a search online but be helpfull if anyone does this often.
BIG thanks in advance guys and sorry to ramble on! may be a few more questions soon as i need this quote done today cheers!
