bigspark17
1,553
736
101,788
wales
United Kingdom
Electrical Engineer (Qualified)
Hi where could i get hold of a voltage monitor or similar that is designed to keep track of supply voltage.?
I have a commercial site 3 phase that i suspect is loosing voltage on one phase causing some issues around site.
Any help or past experiences appreciated.
Google
hire power quality analysers
Reactions: bigspark17
You could hire a 3 phase data logger and set it to log at desired intervals, alternatively the DNO will often do this for you for free, if you give them reasonable cause to investigate a supply fault. I assume you know which phase you think you’re losing, in which case you could take some basic min/max readings with a suitable multimeter.
  • Agree
Reactions: James
If they have a ups for IT equipment, it often has logging built in.
If you are lucky, it is on the phase you are concerned about.
bigspark17
wales
United Kingdom
Voltage monitor ac 230/400v
bigspark17,
James,
