Discuss Voltage monitor ac 230/400v in the UK Electrical Forum area at ElectriciansForums.net
bigspark17
Hi where could i get hold of a voltage monitor or similar that is designed to keep track of supply voltage.?
I have a commercial site 3 phase that i suspect is loosing voltage on one phase causing some issues around site.
Any help or past experiences appreciated.
You could hire a 3 phase data logger and set it to log at desired intervals, alternatively the DNO will often do this for you for free, if you give them reasonable cause to investigate a supply fault. I assume you know which phase you think you’re losing, in which case you could take some basic min/max readings with a suitable multimeter.
If they have a ups for IT equipment, it often has logging built in.
If you are lucky, it is on the phase you are concerned about.
Reply to Voltage monitor ac 230/400v in the UK Electrical Forum area at ElectriciansForums.net
Hi All, From what I understand, working out the design current - Ib for single phase is quite easy (max appliance power/voltage). For three...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hello, my name is Kelvin. I'm a trainee hydraulic engineer in Indonesia. I apologize if this question has been answered before / if this question...
Hi, I'm doing my Level 3 Electrical Install course, and I'm doing distance learning so most of the work is being done by myself with no guidance...
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
