- Reaction score
- 2,969
What chasers are they? I've not seen one that does that. I'd expect if you take spacers out and replace them with blades all you would end up with is a lot of fine line cuts that still needs chopped out, and a chaser machine with a much shorter life expectancy as it's getting over worked.With some chasers you can replace the spacers with additional blades to cut a clean chase and avoid running the sds chisel down it. Useful trick rather than just 2 blades
I've a Metabo MFE40 and it has a blade that can cut out the chase, but from what Metabo have said unless it's very soft material then the blade won't last long...at over £100 a blade I'd be looking more than a handful of chases out of it. The blades are a little offset so they cut into the chase rather than like 3 blades together. But looks like it only really suits thermalite or the likes.
