SiFiSu
Hi, I am having weird behaviour from my flat's electrics which I think will need an electrician. The flat is empty whilst it is being redecorated and there is nothing plugged in.
With no load the RCD trips some days and will not reset but other times is fine. I have discovered that if I switch off the MCB for the 13A sockets in the bedroom and living room it will reset.
As it is an intermittent fault, even when there is no load, should I be suspecting the consumer unit or MCB? And if so will I need a new consumer unit or are replacement MCBs still available?
Sorry for all my questions but I would like to understand what is the likely problem, thank you, Simon
