Discuss What are the wires that go thru the outside box used for? in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 wires going thru outlet box outside and need to replace with a round 4". What are they for and can I cut them? The house previously had security wiring throughout. Thank you.
You're going to need to provide much more information before anyone will commit to anything resembling advice. Photographs are probably the best option showing the cables, where they enter/leave enclosures etc.
Got it figured out. They were nails used to secure the box. Thank you.
Reply to What are the wires that go thru the outside box used for? in the DIY Electrical Advice area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Good day. Is there something wrong with this junction box (code violation) for a wall fixture? It is secured to studs. Old construction. Need it...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
