Discuss What is an electric "amp"-? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I believe "current" is the rate of flow
I believe "watts" volume of mass
I believe "volts" is the force
Then again I am not sure.
Then again all the above are means to measure something from different points of view while not understanding/explaining what "it" is.
This may help
volts is an potential didfference, or electrical "pressure" between points. current will flow from 1 point to another (amps), matgnitude dependentt on impedance betweenthepoints. aas an analogy. a largeg bore water pipe will carry a largge volume of water. whereas a narrow pipe will restrictthe flow. (think of a thicker cable passing more current). watts is the actual power dissipated by the cable and the load., Volts X amps.
An amp is a certain number of electrons flowing in a certain time. If you want the exact numbers it's 6,240,000,000,000,000,000 electrons flowing per second.
This may help
Thank you for the link. I have created a link to review in the future. Now please do me a favor and look over the attached drawing. I have been told that it will not work and yet no one could tell me why. On a side note, this model could be scaled down.
You will need to scale the drawing down. The current scale is one to one.
wish you and yours the best today and forever more
  • SEAPOWER44 (1)_optimize.pdf
I somehow knew what this diagram would be, perhaps I am psychic.
What has it got to do with your original question re volts/amps though?
Reply to What is an electric "amp"-? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
I installed a timer on a hot water heater. I made sure it was rated for the correct volts and amps and I believe I used what gauge wire the water...
Imagine me, in my car wanting to listen to loud music, i turn it up and bam it cuts outs. I soon find out that i can make it work again by turning...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
