Search the forum,
Discuss Product defect or installation error? in the UK Electrical Forum area at ElectriciansForums.net
Flex is multi strand wire as opposed to single strand, the bootlace ferrule referred to is a metal tube the multi strand is inserted into and the tube crimped around the flex and this is inserted into the slot and the screw tightened onto the ferrule.
What's the make/model of this timer? Seems a lot of corrosion on the (steel?) terminal screws for a unit that was only installed a couple of months ago.
I'd assumed heat damage, but upon enlargement of the image that termination screw on the right shows considerable evidence of corrosion.
Here's product description even though it doesn't list model number.
DEWENWILS Pool Pump Timer, Digital Timer Box, 2HP 40A 120-277 VAC, 7-Day 20 ON/Off Programmable Timer Switch for Water Heater, Pool Pump, SPA, Motor, ETL Listed​
Reply to Product defect or installation error? in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
