Discuss what is tabulated Rating of current in the UK Electrical Forum area at ElectriciansForums.net
it's the current capacity of cable/s as seen in tables in BS7671 and OSG. e.g. 2.5mm cable clipped direct. is 27A, less if in insulation. variuos intallation methods give here:
see OSG page 156 table F4(i),
Thank you Vortigern: could you pleaese share BS7671 cable current capacity table. It will be great help
there are several tables for different types of cable and the installation method used. get a copyof OSG , only £20.
loads of tables and info for various cable types here:
e.g. this table is for T/E.
Reply to what is tabulated Rating of current in the UK Electrical Forum area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
  • Poll
I did a poll last year on exactly this. Below I have pasted what I wrote in thread last time so there is a degree of similarity. We can then see...
6K
Hello Can anyone confirm for me what the following spec for a Wago TopJob 2202-1201 din rail connector means? The connector can accept max 4mm...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
