Discuss What size wire do I need? in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a 100 amp sub-panel in my garage that I would like to put a 60 or 70 amp breaker in and run that out to my shed about 175 feet away to another panel. My limited electrical understanding leads me to think that going such a long distance might cause excess heat from resistance? So...my question is what size wire do I need going that far that wouldn't over heat causing a fire. Is there a formula for this? Also, what size sub-panel can I use in my shed feeding off my 100 amp panel in the garage?
Thanks for you time and knowledge!
AD
AD
How are you my friend with a distance of 175 feet. Go with 60 amp because you pull probably will only pull half of that. As far as wire goes you need # 1 copper x 3 and one # 10 ground with an insulation of THHN which would require 11/2 PVC conduit
Reply to What size wire do I need? in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
