Discuss Where to connect power cord to induction single phase motor 240v in the Australia area at ElectriciansForums.net
Joe9009
(I would want it to run clockwise)
Any guidance would be much appreciated.
Or plot them on a piece of paper and take a pic of that, include the terminal links.
It is a motor which can be powered from 110 or 220v depending on how the terminal links are connected. What voltage are you applying, 240v?
i guess it must be 240v from the power of my house?
[automerge]1585924691[/automerge]
Online it says standard voltage in oz is 230 but 220v machine can be used?
Yeah it should be okay on 230v but it will spin slightly faster. You need to remove the links and reconnect as per the third diagram on the top. Post a pic when done and I will tell you where to connect the 230v.
U3, Z2 and U2 linked. Then U1 and Z1 linked.
Yeah is should be okay on 230v but it will spin slightly faster. You need to remove the links and reconnect as per the third diagram on the top. Post a pic when done and I will tell you where to connect the 230v.
OK, that must be the third diagram under the circle (or CW) with the plus inside it.
[automerge]1585928807[/automerge]
The mains goes to U4 and either U1 or Z1 doesn't matter which way around. Is there an earth terminal.
Does Z2 still have its yellow wire connected with the red.
on Z2 there is a yellow and red wire mated.
[automerge]1585931786[/automerge]
I don't see a separate earth terminal, and wondered about that.
It runs without the earth wire connected
what do you think?
the tray that's screwed on to hold the capacitors, i suppose i could connect the earth wire on one of those screws if need be?
It definitely needs an earth do not use it without one. Is there not a screw in the corner of the terminal box.
Reply to Where to connect power cord to induction single phase motor 240v in the Australia area at ElectriciansForums.net
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Hi I have inherited a compressor with a single phase motor but its been stripped and I need to fathom out what's what.. I don't know if it even...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
