Discuss Wiring a new 2 gang socket in the DIY Electrical Advice area at ElectriciansForums.net
personally, i'd not bother earthing the back box. it's enclosed and untouchable.
Be touchable when someone knocks the new plastic surface box off the wall.
Well you could use one of the old face plate fixing points with a small eyelet crimp.
I'd agree....why not pay an electrician to come in and do a proper job, ensuring you and your family are not put at risk?
Because I'd rather not be charged ÂŁ50 to have 3 wires connected for me. Now that it has been explained to me it seems very simple.
So is connecting a gas fire....difference is you'll smell the gas before something goes wrong. Looking at the picture the installation is probably over 25 years old.
I guess each to their own, just make sure you isolate safely and pull test the conductors once connected. You would not believe the number of times I've taken a DIY socket of the wall and a conductor falls or has fallen out, meaning the installation may have been a fire hazard since installation. There's a lot more to it than just connecting of 3 wires.
The pattress you have looks like a deep 45mm, usually used for cooker/shower switches. You could use a shallower 25mm for a socket which would look neater on the wall.
Although id agree with the above, not being a straightforward swap id get a pro to come and sort it for you.
Reply to Wiring a new 2 gang socket in the DIY Electrical Advice area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
Looking for a metal pattress with screw fittings in the correct place for this old MK 2 gang socket. The existing pattress of the socket that I...
