Discuss Wiring an add on DRL to vehicle - relay use and diode? in the Auto Electrician Forum area at ElectriciansForums.net
Hi
My daughter wants to add some DRLs to her car.
The wiring diagram attached is being followed.
I had heard that relays require a diode across the coil so I have shown one in the illustration (see grey line work).
Is a diode actually required in this application or not?
DRL = daytime running lights
Reply to Wiring an add on DRL to vehicle - relay use and diode? in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
I am trying to replace a mechanical switch from an OLD ice machine with an electronic timer. The existing switch has only 3 wires, a Black Power...
Current Situation: I have three 20amp breakers with 12 AWG in the main panel. Each wire ends in a 3x2.5” metal box along with one neutral wire...
I have an inverter powered by a car battery that I use when 220V power goes off (see block 1 below). I use a battery charger to charge up the...
