I'm fitting my new single oven in the kitchen. the existing cable is probably 6mm with a large switch on the counter. the new oven has a total connected load of 3.5kw and recommends a 16A fuse.
can I wire on the end of the 6mm a cooker terminal block and single 13a socket, as I want to put a microwave above the oven, would I need to reduce the trip size? I'm just wondering as the cooker switch has a built in socket, does that mean that socket is protected by a 40a mcb?
