Discuss 3 phase and immersion heaters - please advise in the UK Electrical Forum area at ElectriciansForums.net
oddbods
Hi all,
i thought id join your forum to get some advice...
i run run an exterior cleaning company and we carry large amounts of water on our vans, during the depths of winter we heat the water with immersion heaters so far this has not been a problem as I've use 16 amp sockets etc..
we we have now moved into a bigger industrial unit which has loads of 3 phase sockets, and limited supply of single phase, my question to you guys is....
can an I use the 3 phase to power immersion heaters ? Will it be safe ? Can I just plug them in or should I have/need some special bits and bobs
thanks in advance
darran
If you have 3-phase 5-pin sockets (i.e. TP+N+E) of the same rating as the single-phase ones you have been using, then it would normally be possible to use your single-phase heaters by fitting TP+N+E plugs and wiring the heater to one of the three phases. However some 3-phase sockets and circuits, such as those used for machine tools, don't include a neutral connection (i.e. they are just TP+E). These would not be suitable to supply a single-phase 230V heater.
Thats great information many thx :biggrin5: - the unit has been empty for a couple of years and was a bakery beforehand, I had an electrician certify the electrics were safe and upto standard,but I didn't realise most of it was 3 phase, (lots of big red plugs with 415v written on them) unfortunately he's popped off on holiday for 10 days :thinking: but I'll get him to look on his return and let you know the outcome
cheers
darran
There are a few options available if you wanted to change those sockets to single phase.
If there is a neutral there then you could have the socket removed and a small fuseboard put in its place with 3x 16A single phase sockets.
If there are only three phases and no neutral it may be possible to rearrange the wiring to give a single phase supply and fit a 16A single phase socket.
If you don't want to alter the installation you can get distribution boxes which are used in theatre/events work which take a 3ph supply in and have a variety of single and/or 3 phase socket outputs on them.
Something like this:
Reply to 3 phase and immersion heaters - please advise in the UK Electrical Forum area at ElectriciansForums.net
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
