gr7
Sep 28, 2010
120
Hampshire
www.silverstreamsolar.co.uk
Business Name
Silverstream Solar Limited
I have been asked to replace a module damaged by a fallen tv aerial in the recent storm. The system was installed by another company that has gone into liquidation.
Customer has sent a photo of the damaged panel. What draws my attention is the mounting system, instead of the usual clamps there are large washers holding the module to the mounting rail.
Can anyone identify this mounting system please?
These are Solarworld modules by the way. My suspicion is that the installers did not have clamps suitable for the 31mm frame so used the bolts from the clamps they had with large washers. I'm thinking it may be necessary to replace the mounting system as this does not look right to me.
that's the solarworld mounting system.
If you're looking for a replacement we have some of those panels in stock assuming they're the 250Wp models. The new model have 33mm frames, so you may struggle to get replacements from main suppliers.
Thanks for the info Gavin. I was also asked to line the top and bottom row of panels at the same time as they are about 100mm out. Customer had asked the installers to rectify this with no success. Given this poor attention to detail I was concerned that the mounting system had been bodged.
I'll have to get round there and measure the panels as they were only installed 8 months ago, do you know when Solarworld started shipping 33mm?
Thank you for the offer. I'll get back to you if I get stuck sourcing one.
Having checked a data sheet I notice the 33mm panel was introduced in 2015 so these could be 33 or 31mm. I'll have a measure up and give you a shout if I need a 31mm panel. Cheers.
actually I think they're the 33mm panels but used with the clips from the 31mm panels. The corners are black plastic on the new panels, vs aluminium on the 31mm panels. The new clips are rectangular.
I'd take some spare tiles with you as odds on there will be broken tiles under those panels if it's a shoddy install.
Yes they are 33mm panels. The aerial guy measured them when he was up there over the weekend, he even emailed me a picture as proof. Good point about the spare tiles, I have a load of these kicking around anyway.
As I'm not familiar with the Solarworld mounting system can you tell me whether it is acceptable/safe to use the 31mm clips? It's always a concern when working on someone else's dodgy install as the responsibility passes to my company.
Use the STA's repair agreement template: The STA Repair Agreement - Solar Trade Association
The repair agreement is one of many things we do to support the industry. Why not support the industry back by joining the STA and getting involved?
In the current climate I'm not really in a position to join the STA. If things pick up a bit I'll certainly consider it.
I think we have done on commercial roof with low wind loading, wouldn't be so keen in a higher wind loading area.
I'd just replace it but note concerns about the wrong clips having been used and state that you can't be held liable for it (or use new clips for your bit)
That was along the lines of my thinking. I'll have a better idea of how comfortable I am with them once I get up there. If I'm that concerned I'll raise it with my customer and give him the option to replace the clips with the 33mm ones or sign a disclaimer.
gr7
Hampshire
Website
https://www.silverstreamsolar.co.uk
Business Name
Mounting system identification
gr7,
gr7,
