Discuss Amd 3 compliant, metal, two module unit in the UK Electrical Forum area at ElectriciansForums.net
polo1
As above, can anyone recommend a make/model of metal housing to accommodate only an rcd? I'm guessing too, that these will require a metal cover if used in a domestic setting?
Yeah, that's what I want to avoid! I do a fair bit of work in rentals, where lots of showers have no rcd protection, hence the enquiry.
The OP asked for a metal RCD enclosure not a CU! lol
Well true, but if this enclosure did not need to meet the same standards or satisfy the same regulation as CUs, he could just use a plastic one.
I was assuming this fell under the "similar switchgear" part of the regulation hence the question.
and if he's adding to an existing install then fit an insulated one!
Yeah, I was posing the question for two reasons. My understanding is that, in the situation I described above ( fitting an rcd to an existing circuit), then the rcd enclosure had to be metal, with cover. On this basis, also wanted recommendations for a suitable unit.
i can't see how a plastic/ insulated one complies ( unless others can point to other info).
most scheme providers would beg to differ.
Tend to agree, and with BS7671 being a bit vague on 'similar switchgear', who else can you ask for advice, unless you think you know better. Carry on installing stuff regardless, might make you look a bit wanting if the authors of BS7671 confirm what the schemes are suggesting.
Ok, not many suggestions then :confused5::confused5: NICEIC Tech helpline today confirmed their inspectors expect metal enclosure with metal lid (doesn't have to be self-closing) in the scenario described in my o/p, in order to comply with Amd 3.
Reply to Amd 3 compliant, metal, two module unit in the UK Electrical Forum area at ElectriciansForums.net
Hi, I've done some work in a house, I used an existing 10mm cable on a B40 MCB to supply a 2 way consumer unit to control a heat pump and...
Hi All, thanks in advance for any guidance you can provide. I will of course turn off everyhing at the consumer unit before doing anything. I...
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
