How would you guys ensure earthing for a metal tail gland into AMD3 board; if you dont mind me asking on this thread. Would you provide a banjo and/or fly lead/nut; or scrape off the paint for lock ring ?
Use a star washer/paint cutting washer or else one of those locknuts with the little teeth on them.
Reactions: haptism
Use a plastic gland. There're cheaper than the metal ones, especially the GripLoc ones. :)
Post 24 still no idea what an AMND3 stuffing gland is. What page of BS7671 should I be looking at for a reference.
Reactions: Risteard and Andy78
I think it's a way of riding the coat-tails of a new reg, in the hope it'll increase sales for new products which aren't really necessary.
Been meaning to load these for a few days I put the tails gland agenst the board to see for size. There's a 20mm stuffer and 20mm coupler just for size reference. The tails gland is massive so that is being sent back and I'm going to go for a 32mm stuffer for the tails.
But you wouldn't get 2x 16mm tails in a 20mm stuffer would you? And if the tails are 25mm?
The only issue with the bigger gland is cutting the damn hole. But the bolt up plate cutters make quick work of it.
Yes I know you wouldn't get tails in a 20mm stuffer they are just there as reference as to how big and clunky the 40mm tails gland is.
I am going to go with a 32mm stuffer for the tails as they enter from the bottom
The Griploc 25mm tails gland is 32mm, is that the one your referring to?
How do you mean? Ive not had to cut one yet. CU's normally come with a 32mm knockout, Can use a stepdrill if you need to make it bigger for whatever reason.
Reactions: Wilko
416.2.2 A horizontal top surface of a barrier or enclosure which is readily accessible shall provide a degree of protection of at least IPXXD or IP4X.
Glasgow
Business Name
Udell Electrical Services ltd
AM3 Tails Stuffing gland
Gazthesparky,
bill01803,
