Currently reading:
Bizarre Wiring And Readings Through Upstairs Windows
Discuss Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
G
Gemma
Hi
I don't know if anyone can help, but I'm very grateful to anyone who can provide input. I won't go into the full story, but my windows upstairs appear to have an electrical current running through them.
It's only the windows upstairs.
They also set off a radio frequency detector.
Even if the fuse box is powered off, they still give an electrical reading.
It is not a home security system. Just bog standard double glazing.
The house was re-wired (not by me) and the electrician I had over recently noted what a mess it was and the upstairs and downstairs aren't on seperate circuits.
I have a photo, but I can't attatch it. It shows the window handle giving off a 12v reading, the same as my power points.
I also have a video of the windows setting off the radio frequency detector.
My friend, a glazer, came over and used a thermal imaging camera and we noticed the windows had unusual hot spots on the frames.
I have a feeling it may be being used for some kind of surveillance system that I am unaware of.
Very weird question I know, but any advice is greatly appreciated.
parabolic.... similar to alcholic, but a parabolic has a tendency to parachute out of perfectly good aeroplanes. due to the forward speed of the aircraft, until the parachute opens, the parachutist's travel through thin air describes a parabola. hence the term.
bolics
I know this is a silly movie, but it's got aliens (so maybe connected to the OP?) explosions and very big 16" guns that fired projectiles weighing a ton over 20 miles. And that track :)
Best bit is 4:30 ...
The solution is to buy copious amounts of aluminium foil and put this on the walls behind the paper and paint. cover your window panes with the foil and it will protect you from the potentially harmful currents and signal waves. All just in case you are being monitored. If you have any foil left on the roll you can make a hat to wear when driving and out the house.
Jesus 47 posts & still running, unusually the OP seems to have legged it. Either as said by vortigern earlier, it's a wind up. Or she's been carted off to the funny farm in a strait jacket. :rolleyes::confused:o_O
Anyway we learned something new again today, There is someone out there crazier than us lot :eek::p:D
Reckon She has been abducted by the Aliens, or the lectric Police
Hi Gemma ,
first of all I would like to apologize for the amount of smart-arsed comments posted on your thread. Electricians has a somewhat bloated self of self importance when it comes to electrickery and also have a tendency to forget just how strange and , at times , terrifying electricity can be to people who have had little or no training in the matter. These people were , more often than not , crappy apprentices who were still getting the brews and butty's in their 3rd year and continued to be treated throughout their miserable lives with no respect due to their bitterness at failing to become plumbers.
ok , so first up , the tester you are using is notoriously unreliable and if you touched must object around the house you would get a similar reading.
The radio frequency detector you are using , would probably , depending on which type of conductive metal you are aiming/in contact with , would trigger anyway as most metals are refractive in their affects on radio frequencies and this tester is simply showing that.
In order to install any kind of secret transceiver or listening device , you would need a power supply and normally these are fitted in specialist light bulbs or sockets.. never(not once... ever) have I seen one fitted in a window. The warm spots you are talking about may simply be that your windows have developed a fracture in the seal and are allowing moisture and air in.
Rest easy , ignore the --- clowns on this thread and don't be afraid or intimidated by your lack of knowledge to post again as most of these bullies will be dreaming of unblocking drains when they should be helping people out.
Plungers at the ready , ladies.
Reply to Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
