G
gazroo
Hi,
This afternoon, finished re-emulsioning a plasterboard ceiling in a 25-y-o house (so the electrics are modern enough).
I had removed a circular metal light fitting - the swivel 3-spotlight type of thing - but it uses modern LED bulbs. Never ever had a problem with it. The wiring is solidly connected and the fitting not heavy, so I let it dangle to ease painting above/around.
Finished the final coat and didn't let it dry but immediately screwed the fitting back onto the metal plate which is itself screwed to the joist. I'm confident no wires were trapped but switched the light on and - bingo - tripped the fuse box.
Removed the fitting again and let it dangle. Switched the fuse box back on. All circuits worked again and all three bulbs were now working too. In fact, whilst dangled, the fitting is turning on and off just fine, but I'm nervous about fixing it back to the joist plate in case I trip the electrics again.
Could the damp emulsion have been the culprit, or is it likely to be another reason ?
Thanks for any suggestions.
