A
aw1993
Hello,
I hope this is allowed here! Please let me know if it isn't. Keep in mind I have 0 electrical knowledge.
A couple of weeks ago just 1 socket in my bedroom failed. Everything just turned off and wouldn't come back on (seemingly 0 power at all from that socket). But the other socket in my room is fine.
I unscrewed the (faceplate?) to have a quick look at the wires, they all looked in good condition and as far as I could tell, without going too near the actual wires, they all seemed screwed in nicely.
They seem to be extremely old type of fuze, which I can't even find an example of online? Other than in this video,
Any advice on what this may be would be greatly appreciated, could it possibly be a blown fuze?
Unfortunately we just aren't in a position to be able to hire an electrician, if we were we'd have had this old fuze box replaced years ago! So I'm hoping some bright-spark (pardon the pun) could maybe help me?
THANKYOU!!!
Without some basic test gear, doubt anyone can really help.
Those fuses aren't all that old, but ideally want replacing at some point as there is now safer technology about.
If it is only 1 socket not working, doubtful it's a blown fuse. However, you can pull them out an look, there will be a thin silver coloured wire inside the carrier. If unbroken it's not blown.
An electrician shouldn't cost a great deal.
Reactions: Deleted account
Hello,
THANKYOU!!!
Although it could be a blown fuse, it is doubtful as most sockets are wired in a Ring or Radial circuit and contain more than just one socket, how many cables are present at the socket you have removed? it could be that the nearest socket to the one you have taken off could have a loose connection.
It's not advisable for any Forum member to tell you how to proceed, apart from being dangerous it's against Forum rule to hand out step by step advice, calling an Electrician shouldn't mean He / She will insist om a replacement Consumers unit (fuse box), although there are those that will, not many but they are about, it may well be that you do require one.
So the best and safest way out of your dilemma would be to call one out to take a look.
A member close to you may offer to help, give it a while until they all start coming home and logging on, you could be in luck, there are some kind people who are members, who may offer to help, you mentioned you have 0 experience in electrics, so in all honesty it would be foolish for you to go fiddling with something you don't understand, food luck.
Reactions: Baddegg and DPG
Hello,
Many thanks for both of your replies.
1 - I did pull out each of the fuzes in the main box and as far as I could tell all the wires looked in tact. (If it was a fuze, wouldn't both the sockets in my room have failed)?
2 - About 2 years ago, we did have an electrician look at the main fuze box and quoted over £500 to replace it but this is out of reach for us.
3 - I will definately stop doing it myself now as I know how deadly electricity can be!!
I guess I may just have to make do without the socket.
REALLY appreciate the responses though!
Reactions: Pete999 and DPG
Just making do without the socket is not advisable. If the cause is a broken or bad connection somewhere then this could cause overheating and/or overloading of part of the circuit.
As Pete said, get it checked out for your own safety.
Just making do without the socket is not advisable. If the cause is a broken or vad connection somewhere then this could cause overheating and/or overloading of part of the circuit.
Agree, beat me to it.
I see, hopefully there is a member here close to me who might be able to have a look?
I've been debating buying a 'Socket Tester', do you think this may be useful or would you skip that and just get an electrician in? (Worried now)
Even if you get a socket tester, you don't have the experience to be able to fix the fault. Put the money towards an electrician.
Reactions: Pete999 and aw1993
Should only be an hour or two for a decent electrician to at least diagnose and make sense.
Not sure of the going rates around Staffordshire, but I would expect around 100quid not far out.
Great, you think I could find one around here? Or maybe a site like CheckATrade?
Personally I wouldn’t advise check a trade.
Others may disagree.
Better to get someone recommended to you. Ask friends and family who they have used and if they would recommend them.
There was a feature on here to view electricians local to you. However I am not sure if it is working yet since the forum upgrade @Dan.
I would see if any friends or family can recommend you one first, rather than check a trade. There are good people on that site, I also believe there are a lot of cowboys. I'ever seen or used it, that's just my opinion from what I have read from the people on here.
post your location. I cover North Staffs, as far down as Stone, or possibly Stafford if I have another job in the south of Stoke.
Told you someone would offer to help if they are close to your location, you wont go wrong if Tel helps,
Leek is fine with me. Can you cope till Saturday?
Great example of what a good forum is all about.
Reactions: Barry123
Plus, most on here can vouch for Tel being a stand up guy.
Might need to check your car has security wheel nuts though.
Might be a bit unsteady after several pints of Hobgoblin, standing up I mean.
security nuts.... pffff.... only security nuts i can't get past are the warders.
Reactions: Barry123
Random Socket Stopped Working
aw1993,
telectrix,
