Discuss Consumer Units under stairs in the UK Electrical Forum area at ElectriciansForums.net
This perplexed me as I pondered why you ouldput a potential fire hazard under an escape route but then I thought surely that a) the enclosure should be able to self contain /smother a fire within it and b) even without the assumed protection of a), the stairs should be suitably fire rated as an escape route?
You may want to consider access though, the required height of installation is to enable disabled or otherwise infirm persons to be able to safely access. That object may be defeated if it's tucked away under the stairs.
And it also needs consideration/Hazard analysis/Risk assessment, that the inevitable junk that ends up under the stairs in a cupboard will inhibit access in the case of an emergency.
I'd have said yes given that the metal with appropriate fire barriers in place should contain and not aid the spread of fire.
However I personally wouldnt as from doing EICRs everyday I know it's a right pain because let's face it space is limited and normally that's where everyone stores their junk! And also it could depending on the house be difficult to meet part M of the building regs.
nevermind that. how does one reply with 1 word? please be quick before this post gets deleted for being off topic. :(
Post three words, then edit it to what you want.
[automerge]1584023638[/automerge]
Voila
[automerge]1584023858[/automerge]
No worries next time I see a post and someone has answered i guess no one else needs to chip in with a response if it's the same :rolleyes:
Don’t worry, your not the first. Even done it myself. Just click a little agree after the fact.
Reply to Consumer Units under stairs in the UK Electrical Forum area at ElectriciansForums.net
Good morning guys Was looking for advice with regards to installing an outdoor consumer unit. Customer is looking for power to be installed from...
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hey everyone, working on a new build house and outside garage is wired up like this, however customer wants a Garage Consumer Unit instead of the...
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
