Discuss How to Calculate Size of Cut to Set Cable Tray in the UK Electrical Forum area at ElectriciansForums.net
I worked with cable tray about 40 years ago and remember I created a couple of simple formulae to work out how much triangular section of the cable tray to cut out to do various sets. I have tried to explain them below. The first one is when you know the angle you want to create and the second is when you want to make a parallel off-set.
1. How to calculate the size of the cut-out section (D) for a pre-determined angle set
Eg. You have used your protractor and worked out you need to make a 22° angle in a 600mm cable tray. By applying the following formula you can quickly find the size of the cut-out section that you need to cut out of the side of the cable tray, or gutter-type section to make that angle.
(A) = cable tray width (600mm) and B = Size of angle (22°)
First, you have to find (C) which is found by dividing 90° by (B) 22° = 4.09 (C).
You can then calculate the size of the cut-out section by dividing the cable tray width (A) 600mm by 4.09 (C).
So the size of the section you need to cut out of a 600mm cable tray to make a 22° set = 600 ÷ 4.09 = 146.7mm
How to make a parallel off-set in a cable tray
The other common calculation you need is when you have to work out the amount of set required to make a parallel off-set eg when you have to set a cable tray or gutter around a pillar or set to an off-set wall.
In this case, say you have to create a 350mm off-set in a 600mm cable tray to go around a pillar. In order not to create too sharp a set you want the set to be over a distance of 1500mm (ie. in a straight line, not on the angle).
To calculate the size of the cut-out in the cable tray in this situation you divide the distance between sets by the width of the cable tray ie. 1500 ÷ 600 = 2.5, then divide the amount of off-set by 2.5, ie. 350mm ÷ 2.5 = 140mm. To get the most accurate results, while the set will be close, it is always best to do the first set then calculate where to do your parallel set cut by positioning the tray.
Or
You get your chalks out and draw a 1:1 scale diagram on the freshly laid concrete floor....
Seriously though. Thanks for this. Offsets in tray, trunking etc was all part of learning the trade back in the past.
I just measure and slice as i go like a machine... I always wanted to know exact messurements but just go with the flow with your tapemeasure bro
All rhythmic lad this fine Monday, but knowing where your tray has to Sit and tapemeasure. As for angles its all slicing the edges, removing side wall, and sometimes just the top trim of side wall..
Reply to How to Calculate Size of Cut to Set Cable Tray in the UK Electrical Forum area at ElectriciansForums.net
Hi Would someone kindly let me know the formula to create a flat 45 in say 100 mm cable tray for example. So I can then use the formula on...
11K
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
I am an enthusiastic retired engineer rebuilding a barn in France from scratch and am having problems sizing my incoming electrical cables. I have...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Correctly closing off a dead twin and earth cable in a loft. My old house used to have radial circuits serving night storage heaters. Those...
