Discuss Direct Burial 200 AMP - 250 FT runs in the UK Electrical Forum area at ElectriciansForums.net
This is my first post... I am not an electrician and I am trying to build a house in the Hudson Valley. The quote for 200 amp underground wire IN conduit came in very very hight. The electrician (good guy) said that these covid days conduit has tripled in price. So MY questions are A) is it OK to run direct burial for 240 Feet surrounded by sand and (no rocks)? and if that is OK... what is considered the strongest longest lasting Direct Burial wire made for 200 amp service? Thanks. Carl.
Carl you will need to go to your local electrical store to get tray cable wire which is good for direct burial and sunlight resistant. This wire is going to be costly but @ 240’ I would use 3/0 copper. You really don’t need to add sand, you want the ditch to be clean. Your electrician is correct everything has went up in price and the parts house are struggling to get panels and PVC conduit.
Thanks much... C
Reply to Direct Burial 200 AMP - 250 FT runs in the UK Electrical Forum area at ElectriciansForums.net
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
I don't have much room around my current 200 amp panel and want to upgrade to 400 amp. I'd have an electrician do the work but I am just trying to...
1990s home. 100 amp main feed. Nevada. 15 years mechanical experience on cars + motorcycles. Previous electric exp: I ran the other 50 amp 4-wire...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Last year we purchased a home that was built in the late 1990s It has one outbuilding, sort of a barn/shed about 160 feet from the house (and...
