- Sep 21, 2010
- 7,645
- 7,516
- 10,256,798
- United Kingdom
- Other
- If other, please explain
- Practicing electrician industrial, commercial and domestic.
Making a hole a whole lot bigger always does the trick....or as the Spanish say......Ok thank you, its not for a customer, its for me i like the idea of making the whole bigger
....'Oe'.
Whether the box is soft plastic or metal, a metal cone cutter should do the job, as long as you have the box depth.
