- Dec 9, 2008
- 13,496
- 18,280
- 3,557,381
- United Kingdom
- Other
- If other, please explain
- C&G 17th edition regs
C&G 2382-18 (18th edition regs)
C&G 2394 Inspection & Test
C&G PAT
2 x BPEC electrical courses/exams
Lots of multimeters will test capacitance which will give a general idea of if it’s faulty.
You don’t need an esr meter to test a capacitor there are other ways an esr meter is not a definitive test.
Personally I would be doing some voltage and resistance measurements rather than just changing components in the hope it cures the fault.
Faulty caps often show a good capacitance figure unfortunately. Take it from someone who has spent years in the electronics repair industry. An ESR meter is an excellent way to test if the cap is actually good.
And yes, testing is the way to go, but the OP is probably not competent enough to do live testing on a power supply.
