Discuss How can I create a grounding plug for my antistatic devices in the Electrical Tools and Products area at ElectriciansForums.net
Hi I want to know how I can ground my ESD equipment by way of using my mains points.
eg I have seen a grounding plug for sale that allows you to clip on your ESD devices. You plug it into a wall socket and it uses the earth point to discharge.
The problem is they are not cheap and there must be other ways of doing the same job.
I was thinking about getting a kettle lead or old power cord. Cutting the lead and leaving a length of the earth. Then attaching my devices by means of a crocodile clip to the exposed Earth wire.
Would this work?
Would this work?
Doing such, would probably contravene just about every Safety Code or Regulation going.
Having a piece of equipment that has potentially live conductors, connected to a source of supply, would not be considered very safe.
If you were to attempt something like this, I would suggest using a re-wireable fused plug, removing the fuse, and then terminating a single sheathed conductor to the earth terminal.
UK Plug system.
The live wire and neutral would be removed from the plug.
Only the earth would be connected and then I would connect my devices to the earthed wire coming from the back of the plug.
I don't think £11.40 is too much to pay for the right tool for the job; you're paying for something with a BS number which is a guarantee of safety which you don't get from something you've made yourself.
It seems to be a little more than just 3 press studs connected to the earth pin. But at the end of the day, it does seem to be expensive for just a 13A plug with 3 x 1 Megohm resistors in it. probably because they don't sell many. I would probably knock up one myself, but that's me. I wouldn't suggest poking wires or croc clips into kettle leads was a good idea though. (he says, with just such a thing sitting on the other side of the work bench.:blush5: )
Reply to How can I create a grounding plug for my antistatic devices in the Electrical Tools and Products area at ElectriciansForums.net
I am a complete novice when it comes to electrics but I have recently bought a grounding mat and so I've been doing some measurements and I'm...
Hello, Not an electrician and I currently live in an apartment building. Over the past few years I have been having abnormal problems with my...
These are going to become the norm aren't they? I've been reading this...
I have an old hifi system that has a record player stacked on top of an amplifier. Weirdly, both are wired to the same plug. I don't know whether...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
