E
eiluj68
Hi
Apologies for the length of this post but I'd like to provide as much information as possible
We moved house last October knowing that the property would require a full rewire. Our electrician completed the rewire (including new consumer unit) in December last year and although we were unhappy about his reliability at points during the process, we were pleased that the job had been completed and that he had issued a certificate detailing the work done. The rewire didn't include any work in the bathroom or kitchen as our intention was to completely refurbish these rooms at a later date.
That time has now come and we decided against using the previous electrician due to the reliability issues mentioned above A local electrician came to the house last night to discuss our requirements. He had a few questions about the exisiting electrical set up so I dug out the 3 page certificate that the previous electrician had issued. Upon viewing the certificate the electrician commented that the certificate didn't show which body the issuing electrician belonged to. He said that without the registration body information and registration number the certificate would not be acceptable to building control. He also said that the previous work should have been notified to building control either prior to work commencing by an unregistered person or afterwards by the registered 'competent person'.
This set off alarm bells. I've spent this morning online trying to find him listed with one of the registered bodies but he doesn't appear on any of the sites I've been to. I've looked at NICEIC, ELECSA, NAPIT,BSI, Kitemark and Benchmark Certification Ltd (CORGI Membership). Are there any others he could be registered with that would allow him to certify his work?
We had used this electrician on a smaller job (wiring an ensuite shower room) at our old home 3 or 4 years ago and had been really pleased with his work. He had issued a certificate for this work too and also came heavily recommended on a local community website, so we had no reason to think he shouldn't be certifying his own work. Although no rewiring took place in the bathroom, kitchen and garden areas I'm assuming that this is notifiable work because he installed a new consumer unit?
I'm not sure what to do next. I haven't spoken with the electrician yet because I want to get my facts straight first. I'm worried about contacting the council because I've read that they can fine the householder upto £5000 if work that should have been notified in advance hasn't been. I also need to understand what we might be forced to do if the certificate is invalid. Are we likely to have to lift all our floorboards again and reexpose all the cables within the walls ?
This is so frustrating because we would never have had the electrician undertake the job if there'd been any suggestion that he could not certify his own work.
Apart from berating us for being so foolish as to take him at his word without checking him out further at the time, can anyone offer any constructive advice on how we should deal with this situation. Although we've lived at our current address less than a year we want to ensure that we don't have any problems when we come to sell in the future.
Many thanks for taking the time to read this and for any useful advice you may be able to provide.
eiluj68
...But if safety is also your priority,make sure the scheme member and importantly the person actually doing the pir, is competent and dont rely on that membership alone
If you get a pir of a competent electrician you will more than likely have no problems whatsoever when you sell
You will find your concerns at the moment will become wonder at why you thought there was a problem at all
Thank you. Having been the recipient of so many useful and informative responses on this forum has enabled us to take a more balanced view of the situation.
Whilst I'm very unhappy that the electrician lead us into believing that the certificate he issued complied with current standards, I do understand why he might feel that the new regulations are a waste of time and money for someone with his experience. On the other hand, the consumer needs to be protected against someone with little or no experience/competence. Whether the current system addresses this point is debateable.
I do think that it's important for potential customers to be properly informed and to that end I will probably add a post to our local community forum recommendations board suggesting that people check in advance that the electrical work they have done will be certified properly and that they understand the value of that certification. Just because someone is Part P registered it doesn't follow that they will necessarily do a good job. Similarly, someone who isn't Part P registered can still do a good and safe job. However, there are legal obligations on the householder to ensure that any notifiable electrical work done is correctly certified and if they fail do this there is the potential for problems when a property is sold on, even if the local authority building control are too busy or uninterested in getting involved.
Reactions: 2 people
Thank you for providing such informative posts eiluj68. Good luck with your next step.
Folks - on the basis that any domestic client is usually a lay person, unless an electrician specifically says work will not be notified to LABC (even though it is supposed to be), I would wager that they have failed in their duty of care to the customer and should be liable for any costs that arise from that failure to notify. Isn't this a case for lawyers, perhaps after a "this is what I think what are you going to do about it" discussion with the sparks?
Just what is this 'Part P' certificate that people keep referring to? Is it just an acknowledgement that is sent out by a scheme to confirm that works have been duly registered with LABC?
And I think max allowed Zs's are wrong, as well as what Rappid commented on. And there is something going on with his max measured Zs when compared to the R1+R2 and Ze. But doesn't look too bad. He seems to be a sparky. Just didn't log it with building control. Eiluj68, when you get the next load of works done, get a bloke who will log it with building control and ask him to issue you with a completion cert for the work he does, and register it with the council and a periodic inspection of the works the other bloke. That should cover you. Sort of! did.
Good point JamesBrownLive. I have never seen this mythical Part P Certificate. All I've seen is a piece of paper with my name on it, sent to my customer, from the niceic. I think it says certificate on it somewhere. And something about a 6 year guarantee. But Part P? Don't think so
Good reply from simonspark i would say that would be your best course of action if you are thinking of either extending your house or having a new kitchen bathroom etc at least bonding ,characteristics of your supply would be checked to make sure everything was up to scratch.Armed with a new completion cert that would cover you for future house sales instead of paying labc a shedful of money
Its probably just me, but..... Those RCD disconnection times seem incorrect, cooker excepted.
I thought the only circuits that were allowed 5s times were those over 32a and distribution circuits (411.3.2.2)?
Cheers
Hang on. There are many errors here. PSSC 0,23 KA? That would mean a Ze of 10 ohms at 230 volts. Nominal voltages of 230 and 240 instead of 400 and 230. All the circuits should be 0.4 disconnection time. And crazy rcd disconnection times. 11.4 ms etc. My meter only goes down to the nearest hundredth of a second. Not thousandth. Or is that just me with me old meter? Calibrated mind you!
Two things I would like to point out.
Firstly, it is the person ordering the work who is responsible for notification, not the person carrying out the work.
Secondly, there is no requirement to test existing circuits when conducting a board change.
You are wrong. If there are no requirements to test the final circuits following a board change, then it follows that you can reconnect, lets say, old virs with no earth. Or even lighting circuits wired in twin pvc with no earths. It is down to you as the electrician to highlight these problems to the customer before commencing the works. If you install rcd protection as you probably need to in most circumstances, and the new rcd then trips when the circuit is energized, do you say "You got a problem there mate" take the money and go home?
You are wrong. ?
I think it may be time to get behind the bunker with heads down
There is no direct reference to it. However, there are many odd little nuances in the regs. It says you can have a wall mounted light switch in a bathroom. Read on a bit more and it says you can only install fixtures that are suitable to the environment. Which means you cant have a wall mounted switch in aforementioned bathroom
Plus!!!!!!!! The few people who have been fined have been the tradesmen that have installed the electrical equipment. All that happens to the householder is that when they sell up, a sharp-eyed solicitor will see some works have been carried out and that the purchaser will get a few thousand quid knocked off the price
If you inspected and tested the installation before the work was conducted, it would be a PIR.
The only requirement for any pre-testing, is to verify that the rating of the existing equipment is adequate, and that the earthing and bonding arrangements are adequate for whatever protective measure is intended to be applied for the safety of the alteration or addition.
All 631.1 requires you to do is to issue an EIC, detail the extent of the work covered by the Certificate and include a record of the inspection and the results of testing.
It doesn't say anything about inspecting and testing existing circuits.
How do you do this without testing the installation
F
Electricians Jobs
findajob.dwp.gov.uk
F
Not sure what our options are. Advice required for homeowner please.
Australia
eiluj68,
Dunc,
