Discuss PV Hot Water Controller in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
Graham Hilton
Has anyone got any experiences with all these new products that are coming out to direct excess generated electricity from a PV system to your immersion? I'm getting a few of my customers asking about them. The ones I've found seem to just use a relay switch once there is a certain amount available (usual a minimum of at least 1kW). I would have thought there would be a more efficient method. They also seem quite expensive for what they actually are.
Any thoughts would be much appreciated. Seems hard to sell something that might only save the customer maybe £30-40 a year.
I've looked into these as well. The 2 options seem to be a parson switch, which is a very crude solution which may end up costing you more money than it saves, or the EMMA unit which is to expensive to appeal to the majority and over engineered for an immersion alone.
There have been various DIY methods created on this site that sound like they do the job just fine, but none seem to have gone to market, maybe due to patent?
Thanks sambotc
I disregarded the Parson switch as when I spoke to them they basically told me it was just a relay switch in a box AND you needed to drain the hot water cylinder down AND replace with a 1kW immersion - can't see many people going for that.
The EMMA seemed to tick all the boxes until I finally got a price from a supplier and they were quoting £2500-£3000!!
The best option I can see at the moment is immerSUN :: Use 100% generated free electricity :: A 4eco Product . It sounds like it works in a similar way to the EMMA (it modulates the power, doesn't just switch it on when a predetermined amount is generated). When I contacted them they said the RRP was going to be in the region of £300. Not due to be available for another couple of months, but might just be worth waiting for if nothing else comes up.
bath.jpg Or this one.......
This is the controller you need :-
www.sgwooldridge.co.uk/solarpvswitch
Its unique in that it actually senses the net power available for export and diverts it, however small, to the heater, normally a hot water heater.
No need to fit a smaller immersion heater it uses the standard 3Kwatt one ,and never imports power for the heater. It just patienly waits for net surplus of pv generated over consumed power.
Will even power additional loads like towel rail heaters etc if purely resistive.
Operates even at 50 watts surplus power! These are great devices and should save its cost in less than a year.
I have three running on my properties heating background heaters, hot water, towel rails.
The secret to paying back quickly is to ensure that all surplus power is used, even when the water is up to temperature.
You can do this by parrallelling loads, as the maximum output power will not exceeed your peak Solar PV power.
It will even work with a 3Kwatt oil filled electric heater in parrallel with the immersion heater.
You must make sure though you do not import power which this controller won't, but other simpler switches do.
A simple calculation based on say 4Kwatt Solar PV generating 3500kwatt hours per year at say 11p per kwHr could save £385 if you used all the surplus power.
Also factor in you can switch of the central heating from around now, due to the back ground heating, which otherwise I would have kept on just to do the hot water.
Its not an electro mechanical switch, its solid state so it will outlast all the other switches.
Its rated at 30 amps but only ever takes 16 amps given a 4kwatt solar PV system.
It therefore operates well within its rating.
Yes basically, at the simplisic level they are very similar, however the Immersun has roll-over / duel load facilities and timer controls also built in.
What are the timer controls for? I thought the idea was to dump all export generation into a water store instead of the grid?
Yep, however if the system isn't up to temperature by the end of day due to either usage or lack of sun, the the system can then control your normal (or backup source) of heating to provide the nescessary boost.
For example most of our oil customers switch their whole oil systems off from May to October, so rely on the immersion, and the ability for it to ensure that whatever the sun's output that day they have ho****er is invaluable. This is even more important if someone is at home during the day and so has some kind of existing 'base load' and also if they don't have a roof or capital enought to have installed a 4kWp system. So whatever the sun's output and your consumption you are ensured hot water at the cheapest possible cost, even if there hasn't been enough 'free'. To do this with other systems other systems would be far more complicated and far more costly in installtions / controls / eergy consumed.
Thanks Worcester, I see. So the Immersun system could be coupled with a gas boiler to give the necessary boost or top when needed?
Don't know how the **'s got in there!! had to re-read it myself to see that it should have said hot water .
@Mr.Shing-A-Ling - yes that's possible
Welcome on board! Jodi and Lee are great to deal with, good customer service.
@TonyGreen
4Eco / Immersun will only sell direct to Installers.
As an end user consumer, if you buy the unit only you will pay 20% VAT. If you have it supplied and installed, VAT will be at 5% as it is classed as a Hot Water Controller under the reduced VAT guidelines.
To find out your local installer, go to Where to Buy :: immerSUN :: Use 100% generated free electricity :: A 4eco Product
If you are in installer, then the Distributors listed here , will supply at the same trade price as 4ECO, and extend credir and other payment options to installers:
Distribuors: Where to Buy :: immerSUN :: Use 100% generated free electricity :: A 4eco Product
You should invest your money in a solar hot water system, in the form of tubes or flat plate. By the time you have spent approx £500 on PV heat dump, you could have saved £500 on a £3000 solar thermal set up!
The immersion heat dump is messing around with a piddley amount of energy during only peak times of day. Solar thermal is much more efficient for heating stored water, hands down!
With the PV, just use it as a cash cow like everyone else does, some electric is a nice bonus during production hours.
Blueflash
Blueflash
the problem with Solar Thermal, is that like most PV my roof is now covered, so with immersun I should be able to use the spare electricity.
By the way they now have a price on.
immerSun
@TonyGreen that is a trade only price to Installers, Immersun / 4Eco Ltd to help the industry will only sell through distributors and Installers :) Have Spoken with the 'Green Electrician' and they also say that is the trade only price. They will supply to a consumer through their local sparks, - suggest that they should be VAT Regsitered, as supply is at 20% and under VAT Rules 708/6 para 2.6 these can be Supplied and Installed at 5% VAT
I really do wish these trade only online websites wouldn't broadcast their prices to all and sundry :banghead:
Surely can't be that hard to require a trade log-in to view prices now can it?
@TonyGreen prices for installers had been 'outed' in the Sun Lounge a while ago, so wthose that needed to know could easily have found out. So long as you are a registered sparks and not a supplier, you can register to come in to the lounge - same rules as the Electiricans Arms.
Used the "Sola Controla" from sg woolridge been in for about 3-4 years works perfectly. I have checked to make sure it doesn't use imported power and I have never managed to catch it doing it. So 10/10 for me.
I think you'll find Wooldridge don't do it anymore, bumped into them the other day and he was installing one of the better brands.
Reply to PV Hot Water Controller in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
At Electrical2Go, we have recently broadened our product range to include water heaters. Our goal is to offer comprehensive solutions for both...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi all, Yesterday I returned home to no hot water after a few days away. After a brief inspection it seems the fault lies with the Horstmann...
4K
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Was having a look at our gas and electric bills today, and its getting depressing. I would like to keep using our appliances as and when we...
