Discuss Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
as mentioned in my last post would it not be easier to use metal clad 2 module enclosure and fit main switch in it can gland swa straight into it no need for adaptable box
Our posts crossed, but don't forget this is coming out of my pockets, 12 No. 2 module enclosures = expensive, 1 No. 25mm core drill = cheap(skate) :)
Someone tell me the link I sent is wrong.................................
What is it that you're actually trying to achieve here? What's the project?
12 No. new CU's for Bedsits. Everything is electric, no gas. Looking to keep costs down. Got some good advice in another post. Most cost effective option is SWA, but dilema is CPC.
If I can get 2 core in 20mm KO's I'm fine. If not it looks like I can't get off the shelf so will need to buy Adaptable box and drill my own, along with metal CU. Unless I can put 2 core in 32mm KO ?
Reply to Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
I haven't seen a lot of discussion on this subject and have questions pertaining to isolation where TN earthing is present and any peculiarites...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
