K
kkkkk
Hi people
I have an electrical meter to install, DDS353C - A single phase electronic credit meter with LCD readout. It is 4 x module DIN rail mounted with a max load of 100amps and pulse output. At the bottom it has supply L/N & load L/N, no problem - at the top there are positive & negative connections labelled kWh - I am not sure what I connect here - I would appreciate any advice, thanks very much!! :) :)
kWh Meter MID Certified DDS353C
So I don't need this, ok - thanks. How does it work then (I just like to know) in BMS? THANKS! :) :)
Just found this:
As a key element of today's sustainable building management system (BMS), submeters acquire and transmit a variety of energy data parameters for analysis and reporting through the BMS for common area cost allocation, fair and accurate tenant or department billing and other energy-saving capabilities of tangible value to the bottom line. This white paper overviews some of the key issues relative to integrating cost-effective metering technology into today's building management system protocols.
Electricity meter kwh how to wire in at top
kkkkk,
Brightspark2,
