Discuss Repairing Christmas light projector in the UK Electrical Forum area at ElectriciansForums.net
Well that's the problem.
One spring 'brush' contact on the Christmas light motor seems to have got bent, with one of the leaves pulled away in the wrong direction from the others (outlined red below). If that bent back piece was touching the same commutator segment as the other brush, it would explain why the motor didn't run, but had resistance.
Maybe the black is the remains of what were small carbon brush contacts, or it's some sort of grease?
I don't think there is much point in trying to restore it or fabricate a replacement given the motors are so cheap.
If there's enough of the springs left, you might get the motor to run by cleaning them up and bending them together, but I don't think it will last for more than a few minutes, or perhaps hours if you're lucky!
Thanks for your reply, just as well I ordered some new ones base on what you said! Is there a way to determine the RPM and other identifying information on one of these from the internals when it's broken?
Different RPMs are going to change the speed of the projector lights, or in the case of a Furby, perhaps stop it functioning properly.
I believe the speed will largely depend on the voltage you run it at, and the load provided by the friction of what it's driving.
There is no specific rpm as such (eg servo control). Instructions might give a max speed, but you just need to supply a voltage that gives the correct speed of operation.
It's all going well, the motor works and the parts fit. I tried cleaning the round disc containing images of santa, snowman, holly and bells but now two of the images have been destroyed. Does anyone now how they are made/where to get supplies from?
It says "H46-005" and something in Chinese? "Just"?
The images are 5mm each, I think the gobo wheels are a lot bigger.
Disc size is 46mm, central hole is 7mm and the mounting holes are 3mm. The distance from the edge of the internal hole to the centre of the images is 11mm.
I have ordered some printable acetate sheets for my laser printer, I can try and recreate them or perhaps add my own designs. I'd prefer a ready made option though, perhaps someone else has experience with this?
Reply to Repairing Christmas light projector in the UK Electrical Forum area at ElectriciansForums.net
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Led light fixture went dim. I replaced it with a new fixture and it won’t power on. I have 120v with a multimeter at the wire. When I wire up the...
