B
bilbo007
Hi,
I just purchased a 12V 10" electric fan from Supercheap. Brand is Calibre Calibre Thermo Fan - 12 Volt, 10" - Supercheap Auto Australia.
On the box it states max current draw is 7.5A and it came with a 10A fuse. I connected the fan up as per the instructions and it keeps blowing the 10A fuse when I start the car. It doesn't blow the 10A fuse when the car isn't running. I know this isn't recommended but I put a 15A fuse in and it doesn't blow that fuse.
There are four wires to connect on the fan that come off the relay. 1. accessory (Green) 2. battery positive with a fuse inline (Red) 3. ground (Black) 4. power that connects directly to the fan (Blue).
I have wired the accessory to the car ignition, ground to the engine bay, positive to the battery then and there are blue and black wires running directly to the fan.
I've tested the following without the car running:
- Resistance test from electric fan ground to my battery negative terminal and its 0 ohms
- Applied 12V to the relay and tested resistance across it which was also 0 ohms
- Resistance test from blue to black (across the electric fan) 0 ohms
- Battery positive to ground 0.04 ohms
- ACC to ground 0.04 ohms
I can't workout why the fan is blowing a 10A fuse when the car is running. I'm concerned that I will burn out the fan with it drawing over 10A. Does anyone have any other suggestions that I could try to troubleshoot?
Thanks,
Thanks,
