Discuss 16 Amp Commandos 4 core swa in the UK Electrical Forum area at ElectriciansForums.net
I went to look at a job today and the client has two 16amp commandos installed but they are both wired in the same 4 core SWA through two 16a MCBs and the CPC for both is the armouring of the SWA. The two cores go to one commando and the other two go to the other commando(only about 5m away). The two 16a mcbs go back to a 32a RCBO which is solely for the two commandos. My question is, is this acceptable as I’m not sure about the CPC arrangement? Technically they are both on the same circuit at the board.
TIA
They will have poor over-current selectivity between the 16A MCBs and the 32A RCBO but that is not dangerous, just mildly inconvenient.
Assuming nothing life-critical hangs off them but if it does they have many, MANY other problems!
Reply to 16 Amp Commandos 4 core swa in the UK Electrical Forum area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
The garage is 17 mtrs x 15 mtrs in the UKh The house has a 100 amp supply to the house consumer unit. The garage consumer unit is fed from a...
