T
Tynan
Hi there
New member here with a very basic question (I am no electrician!). :saddam:
I have a 19.2 V / 9000mAh battery (for an electrically assisted bicycle) and the wiring on the charge end needs a little attention. Basically one end of the battery gets plumbed into the bike and supplies it with power and the other end is the end that gets plugged into the charger when recharging.
At the charge end one of the wires is broken and needs soldering together, I am ok with the soldering / heat-shrinking and general repair duties but have zero knowledge of how electricity works with these batteries - so to my question . . . . .
When the battery is unplugged from the mains and the charger (and disconnected from the bike) is it safe for me to touch the red wire in this diagram ? (diagram below) ? To clarify I am talking about the red wire coming from the battery at the charging end, when the battery is disconnected from everything (from the charger / mains and the bicycle) is it ok to handle the red wire that protrudes from the battery ?
Thanks in advance for any help on this !!
Tynan.
Tynan,
Tynan,
