G
gos
I have a basement that has 2 rooms. 1 has power and the other has not. I installed a 2.5mm ring in the room with no power, comprising of 8 double sockets. When I went to add these to the ring in the other room I discovered that there is no ring, it is actually a 4mm radial circuit on a 30 amp breaker.
My solution is to turn the new 2.5mm ring in to a radial circuit and join it on the the existing 4mm radial and drop the breaker down to 20 amps. Is this an acceptable and safe solution?
Thank you.
Graham
Thank you.
Graham
