Discuss 3 phone points in the UK Electrical Forum area at ElectriciansForums.net
hi there, sorry if posting in the wrong section
rewiring this house, been asked to put 3 phone points in the house.
now do i run a cat5 cable to each from point of entry point or do i link them.
I know few of you will laugh lol
thanks
daisy chain in telephone 3 pair or cat5. so you go from master socket to slave1 slave 1 to slave 2, slave 2 to slave 3. connect terminals 2 and 5.
link them all together
Master -> Slave 1 -> Slave 2 -> Slave 3
connect the cable in number 2 and number 5
usually white/blue and blue/white
don't mix the colours
^^^Perfect^^^
The incoming "slave" will have blue/white at term 2 and white/blue at term 5. Just connect that to your extension points as if your doing a radial socket circuit without a cpc wire.
i would have added the colour against the number but i couldn't be 100% and i had a small child bashing me with a empty​ bottle of milk
Its only because I did one the other week. I dont have a small child hitting me with an empty bottle atm but I do have a wife telling me to get off this forum lol. I think she has some needs? Now is it terminal 1 or 2? She will tell me when I try pmsl :rofl:
Do you need a ''master'' these days?? I ask, because shortly before i left Cyprus to work over here, i had connection problems with my computers broadband. The telephone company came out after contacting my provider there. After a bit of testing and what have you, they went to the master outlet snipped two wires out, the capacitor, and a couple of other bits, and away they went!! lol!! No need for master outlets anymore on our modern telephone system was the reply, when asked what happens if i no longer want a broadband connection!!
Unless something has suddenly change, masters (with cap, resistor and inductor) are installed on the incoming cable usually blue/white stripe and white/blue stripe. if using all masters the you can connect just 2 & 5, masters to slave are 2, 5, and 3.
If 3 is not connected to slaves then the phones will not ring on the slave outlets
Well everything worked perfectly after they left, broadband and telephones!! Which i why i asked the question in the first place!!
They definitely will ring on just 2 & 5
What’s all this about the ring wire removal then?
Many users on ADSL-Guide have found disconnecting the ring-wire from terminal 3 has improved line stats, sometimes in huge amounts. A forum member sent me this information. (I deleted your email, so email me and I will add your name to the Bibliography)
Many years ago the UK telephone system adopted a different policy to that in the rest of the world. Here in the UK a choice was made to move a ring component, which enables the telephone to ring, out of the telephone and into the master socket.
The main reason for this, involved ‘pulse-dialling’, which has now been replaced by ‘tone-dialling. It was a good idea at the time because it made it possible to stop the ‘tinkling’ that occurred on other extensions when a phone was dialling.
However, there was a downside: To get the ring signal into the telephone we now have to run a third wire from the socket to the phone. Also, since we only need one ring capacitor on our line, and it is located at the 'master' socket, we have to take three wires to all our extensions, rather than the two wires which come to the house.
On most modern wiring you will find the original phone signal connected on the 'blue-white' pair of wires (Terminals 2 and 5) and the extra 'ring' signal connected on an orange wire (Terminal 3), though these colour codes are not always followed.
Now, since ADSL filters only filter the main telephone pair, they must re-generate the ring signal themselves. All of this is of only passing interest but it does mean that you only need to feed an ADSL filter with two wires. The ring signal for the third terminal on the attached phone is generated internally. Since most telephone extension wiring consists of two pairs, you may find this information particularly useful if you need to use a particular run of pre-installed cable for both a filtered and unfiltered signal (However Cat5e/Cat6 has that extra pair remember?). It is up to you if you wish to remove the ring wire, and the reasons for doing so are listed later on in a section that Phil, better known as Yarwell from ADSL-guide as written.
If the incoming ADSL signal is weak, or mixing with a lot of interference, it is possible that the layout of the extension wiring within your premises can degrade the signal even further.
If you suspect that this maybe a problem, then you will need to do all you can to optimise the layout of your wiring.
The basic principle is to ensure that there is only one path for the ADSL signal - from your master socket to your modem. If it is running off an extension then there should be no blind alleys caused by t-junctions or branches on the way. All of these blind alleys should be closed off with a filter so that the ADSL signal cannot pass down them.
Hopefully this will explain the master
Maybe the phones in Cyprus are now incorporating the ring components, perhaps the telephone system all changed since building the house, i really don't know!! All i know, the technician chopped the components out of the master!! To be honest i didn't take that much interest at the time, but the phones all work including the ringing, and haven't had any broadband connection problems since!! lol!!
Reply to 3 phone points in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
