Discuss ~3kw Solar PV array required urgently in CHESHIRE ! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
danesol
Anyone out there ( MCS & REAL accrediated ) interested in supply/fitting a 12 Sanyo N-series 240 or 235 hits / SMA SunnyBoy 3500TL with Sunny Beam so as I can make the Dec's FiTs cutoff date ???
To be installed on a south facing garage roof in East Cheshire within 2weeks ??
Dims:- 3500 x 6200, 30 degree pitch, concrete tiled dble garage roof
Hi Danesol,
I am in same boat as you. You may have to relax your requriements as it may be tough for installers to get their hands on Sanyo panels at this point in time!
regards,
Hi Danesol,
Also interested in helping you and your requirements.
Please contact me at your convenience.
I will pm you my mobile number.
Not sure if you have sorted your job yet, but I have just run your system through my design software and you can not fit 12 Sanyo 240 panels on the roof if you leave the correct border around the edge.
The most you can fit is 9 which is 2.16KWP.
They will fit if you leave 100mm but this is not advised.
Hope this helps.
Also I am now taking orders for the new tariff and with price reductions I can still offer a 9%-10% RTI.
If I can help then please Email [email protected].
Reply to ~3kw Solar PV array required urgently in CHESHIRE ! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all - I’m new to Solar PV, builder we do work for has fitted some integrated panels on his garage roof, there is a velux window nearby. Does...
Hello All, I'm seeking some advice about a solar PV system we had installed in November 2014 please. After 18 months, we seem to be consistently...
6K
crossplot
C
I've been asking on here about getting solar panels for a while but I've hesitated because of the cost and the anticipation that PV technology...
Hi All, Many thanks in advance for any advice, I know this is the place to ask:blush5: Basically I am a 'consumer' who's having a pv array...
Been let down by my Solar PV Installer as they seem to be cherry picking now due to the amount of orders coming in and the new cutoff date now set...
Wiggers
W
