Discuss £40 hamper to the first person who finds me this ladder! in the Electrical Tools and Products area at ElectriciansForums.net
You wouldn't think it would be so hard to find a twin fibreglass step ladder in the UK!
I'm genuinely thinking of just sticking a few wooden steps on to the other side of my existing ladder!
Not quite what I'm looking for @Doomed . The little platform at the top needs to be one that is for hammers, screwdrivers etc. Also, the one in your link will be too long for the van.
See my first post as to the type i am looking for, i.e both sides the same. Oh yes, and it's over £200! :D
I'm a man of my word and I genuinely will send a hamper to whomever finds one meeting the criteria in the OP.
[automerge]1601207159[/automerge]
Now that one is close to what I'm looking for. Just doesn't have the nice tray on top with little holes for screwdrivers, hammer etc. Also, as you say, in Ireland.
soon make a tray to clip on. bit of 2mm ally wth the appropriate holes drilled.
Why do you want it just out of interest?
Good question Chris, I should have explained a little.
Every now and then I have a think about what problems I have encountered on a job and if they are recurring problems. If so, I have a think if I can make this problem go away or at least make it a little easier.
Sometimes I'm in a small area with my ladder and it is a bit of a pain to fold it up, manoeuvre it around, reopen, climb back up the right side..... and then discover 5 minutes later I need to do the same again.
All these little things add up, so I try and fix them as i go along, making life that little bit easier. Less likely to make mistakes and also perhaps leave 5 minutes earlier supping a pint just that little bit sooner :) .
Does a standard hop up not work in most situations? I find I only use my ladders probably 20% of the time now.
Yes, the little hop up is great and I probably use it more than the ladder, say 60% of the time, but the 40% when I use the ladder could be better with some lovely twin steps. Not essential by any means, perhaps more of a treat but one I have decided (in my mildly autistic way) that I NEED!
https://www.NoLinkingToThis/p/dewalt-fibreglass-6-treads-swingback-stepladder-1-83m/1272j
Clocked it.
[automerge]1601233500[/automerge]
Crap it's not the double sided one I think - same model number though?
and it's out of stock.
6 tread with moulded tool tray
Also not in stock
[automerge]1601293817[/automerge]
DeWalt Fibreglass 6-Treads Swingback Stepladder 1.83m - https://nextprice.co.uk/storage-ladders/ladders/fibreglass-ladders/fibreglass-step-ladders/dewalt-fibreglass-6-treads-swingback-stepladder-183m
In stock (according to the website) in budget. EDIT but still not sure it's double sided. I give up now
I have been looking for such a ladder too, and I ended up buying one of those ladders I found in this article. Maybe you should have a look there too, I am sure that you will like something really good for you, good luck!
Reply to £40 hamper to the first person who finds me this ladder! in the Electrical Tools and Products area at ElectriciansForums.net
I'm looking for a double sided (i.e you can walk up both sides) fibreglass 6 step stepladder. I have found this one Industrial Steps - Fibreglass...
  • Locked
5K
Hi. I got a new oven the other day and it was working fine. Last night, I swapped out the 45A wall switch for a brushed brass type one. The neon...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
first day done of my AM2 exam. Just wanted to let people know what I done and if I will loose any marks. So first of all risk assessment and safe...
9K
