Discuss Adaptable box with front entry. in the UK Electrical Forum area at ElectriciansForums.net
If you are insistent on not burying get a few lengths of 25mm galv tube and the appropriate fittings in con lock you won’t need a bender of dia set then
I know what you mean about burying the cable. It would be a bit of hassle trying to lift up the blocks as they’ve been cemented in. I’ve not heard of con lock. Where would be the best place to get it from?
Cef Hyton stocks it basically it it conduit box’s and bends with a Alan key to lock in place and not threaded
Search "conlok" in Google or any other reputable search engine and lots of UK results will be returned.
It may be that individual CEF branches stock the stuff, but it's not listed on their website.
Reply to Adaptable box with front entry. in the UK Electrical Forum area at ElectriciansForums.net
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
I have an older Crouse Hinds board with a 200A service. Due to recent rehab on the house, I found I have the need to install a sub panel. I...
