Discuss Adding sockets to existing ring. in the UK Electrical Forum area at ElectriciansForums.net
E
entech
Good evening all.
I am looking to add two double outlet switched sockets to an existing ring main. It is in a bedroom. At present the circuit is 2.5 mm t&e with a 32a mcb in cu.
I want to break into ring at back of an original socket in bedroom and in-line crimp the new leg in and run to new sockets then back to original socket. Question is will I have to upgrade the mcb to include rcd protection as it doesn't have any rcd protection at the moment??
Good evening all.
hmm.....
hmmm goes along with the right foot tapping.
before he comes out with a comment like you should not need to ask this question if you are competent.
basically...hmm...
was all about you ask a question like this.....but then tootle off breaking into a ring final...
tell me:
do you have any test gear?...
and if so do you know how to use it?
Sorry I don't understand about " tootle off ".
I was always going to have to break into ring wasn't I.
entech, your method looks fine. put heatshrink over the butt crimps, but you really ought to know that all sockets up to 32A for use by general persons need RCD protection. whether you just protect the new sockets that you fit, or protect the whole circuit, is your call.
Reply to Adding sockets to existing ring. in the UK Electrical Forum area at ElectriciansForums.net
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi all, question on extending an existing ring main onto the surface and then re-joining back to in-wall. Is there a ‘correct way’ to do this, as...
When altering / addition to an existing circuit and the RCD is a type AC but you notice DC components within that circuit do you upgrade the RCD...
