Discuss Adjustable breakers in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
brizospark
In the case of adjustable breakers which value goes in the column for protective device
i.e. if it a a 200a breaker and it has been tuned down to 180a?
As the 200A MCCB has been adjusted down to 180A that is the value to be taken. Are there any other adjustable parameters on this MCCB?? Always remember that adjustable MCCBs do not have a common trip value like MCB types. (B,C,D,) They are can be considered as ''one offs'' as there protection levels will vary according to the adjustment values being set on such breakers....
Reply to Adjustable breakers in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
My circuit panel has two banks of breakers, each bank protected by an RCD. One of these RCDs has been problematic in that it trips intermitantly...
Good afternoon - we're considering adding an additional breaker to our "main service panel" which is where the meter is located. That panel has 6...
New member and DIY. I have a 60 AMP breaker going to a sub panel for a workshop. Two months ago I bought an electric car and a 40 AMP charger...
