Discuss advice about getting a bolletin in spain in the UK Electrical Forum area at ElectriciansForums.net
hi there can anybody help ive brought a house in spain and need a bolletin to say the electrics are ok the fact is there not if i remove the 2 ctts that are there can i get it done on the main feed and a empty db then add a temp feed in order to do the work any advice would help
You could try this site, if you haven't already...
Probably find a local electrician, at reasonable cost, to do this for you.
However, they may not provide the boletin if there are no active circuits in the DB.
I suggest you ask for a quote for the works, as you may be pleasantly surprised by how competitive it is.
I was faced with a damaged socket in my apartment, and have the ability to remove and replace it, but it was 32 degrees yesterday and i simply couldn't be ar**d. Local spark came within an hour, fixed it, €20...
Good result, IMHO
Reply to advice about getting a bolletin in spain in the UK Electrical Forum area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hola! I’m in the process of renovating an apartment in Madrid. The consumer unit is fitted with an old 15amp ICP switch. I believe its function...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
