Discuss Advise on hole cutting - steel consumer unit in the Australia area at ElectriciansForums.net
S
scanner
Hello,
I'm installing a new consumer unit in my flat for one of my Part P qualifying jobs.
It's a concrete building with all the wiring in conduit and MICC.
I've got a new steel Wilex CU which has various round knock-outs for the cabling, but a few of them don't line up with the existing conduit etc.... some line up half on / half off the knock outs.
Does anyone know of a tried and tested way of hole cutting across knock outs without "knocking them out".
Also can anyone recommend a good set of hole cutters (metric and imperial) for the job.
Any advise would be greatly appreciated,
Thanks,
Al
Clamp 2 pieces of wood 1 inside and 1 outside of the box and use a hole saw to drill through the wood and box where you need the holes ( no need to drill through the wood inside the box that provides support to the knock outs)
I use Starrett holesaws not cheap but they outlast others I've used
You may have a problem as some knockouts which have 2 small pieces of metal holding knockout to the CU, drill them out and knockout will come out as well.
You would therefore have to put a metal plate acoss the top on the outside of CU.
various methods, I usually fix 2 x 2 galv / plastic / trunkings under/side/top. bush through to existing knockouts, spacing locknut between
This is the method I have seen countless times and advise to use
Depending on the spacing and quantity of the conduits coming through the top,try and pick these up directly,fit 2x2 galv trunking underneath,drilling holes to suit the pipes and the dist board ,bush and locknut with a locknut between to keep the board and the trunking slightly apart
Thats why you clamp the wood in place to stop the holesaw ripping the knockouts out
What I was refering to was not ripping the knockout out but when the hole is cut and the hole cut happens overlap the part of the knockout which is attached to the CU the knockout will come out
Reply to Advise on hole cutting - steel consumer unit in the Australia area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
