Discuss aico mains wired interlinked/radio linked smokes and heat detectors in the UK Electrical Forum area at ElectriciansForums.net
J
juanpabs
A little query for you guys that fit these smoke detectors, I've got a site visit next week to quote up for a landlord requesting more smoke and heat detectors fitted in his apartments. He has explained on the phone that he currently has aico mains wired smoke detectors fitted in some of his properties already, now I believe these are hard wired linterlinked. My question is, can I simply by adding a radio link base to one of the hard wired interlinked smokies then a radio link base to any new detectors ensure they would all be linked? Seems like it should work fine in my head but having never used the radio link bases before and cannot find anything confirming if this is possible.
Cheers
Yes, replace one existing base for radio base......then expand using wireless.
only code one apartment at a time, otherwise all apartment will be on the same code and sound together.
Just to add, I have had several dealings with them directly (Aico) and I rank thier customer service as somewhere inbetween
GALACTIC and Interstellar.
The ony thing to remember when adding the radio bases for remote units is that you will still have to locate and connect a local power supply to them!
Just out of interest....Had to use 12 radio linked 10 year battery aicos on a Georgian property a few years back. This was due to decor and lighting cables being run in old gas pipes...After specs going back a forward, the insurance company agreed, and allowed the system to be downgraded F from proposed D.
Gosh, a bit of common sense applied through sensible communication!
Comes to a point Clive, were you can`t do the impossible..... Building and interior were listed, so we could not damaged plaster light decors, which were very fancy. Insurance company commented that grade F would be better than no detection on a £4.2 million property.
Precisely, but muppets think they can cut corners in relatively modern properties rather than doing the job properly.
Just imagine if somebody downgrades the alarm without discussion with the insurers - the LABC aren't likely to spot a battery unit, yet come an insurance claim following a fire, your £2M PL, would come up well short!
That's what I deleted. I've actually seen it where an installer has forgotten to feed a radio link base but then I thought that there's no way 2 people in the same country could be that stupid so decided to rely on the OP's intelligence
As a slight aside, the postman has just been. He brought me the Aico contractors handybook 3rd edition. Not had time to look at it properly but it looks very helpful
You can never be to sure....been to a house to help out local electrical wholeseller....and the guy hadn`t connected any mains cables, and stated "I thought they were supposed to be wireless"...so again got the wholeseller, to change for 10 year battery wireless aico`s (Grade F)
The radio link bases are good, I have used them a lot. I do prefere the hard wired option first, but these are great.
Aico also do a battery powered wireless one that links in with a 10 year battery in it too, it is about £95 if you need one.
The battery powered one is what we have been talking about...would change your supplier if your paying that much
Reply to aico mains wired interlinked/radio linked smokes and heat detectors in the UK Electrical Forum area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi all Recently we've been having a few issues with smoke and heat detectors.. been fitting them for years and years now mostly without any...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
