Discuss Another fuse board change post! in the Electrical Forum area at ElectriciansForums.net
M
Mynamesmatt
People will start to get bored of me soon!
So im changing my CU in a few days and im just about to buy all the materials.. just need a little help with direction
Ive already got an 18 way crabtree starbreaker, just need to fill it up and need some help with amp rating and protection
Firstly, i need two rcd's for the split load configuration.. im just a bit confused as to which ones i need..
Whats the difference between the crabtree rcd's that take up 2 spaces on the CU, compared to the one that takes up 3? hmm..
Also what ampage do i need to go for, 63a or 80a?
And is an 8kw shower ok on a 40a MCB?
thanks for the help guys
Instyle LED Lighting Specialists UK
P
Plonker 3
Do your cable calcs.
Read the regs.
What your budget allows for.
Think that about answers your question. Should any of that baffle you then I would get a electrician in to do it for you.
G
Geordie Spark
I'm not bored ....... shocked & flabbergasted maybe, almost speechless even, but not bored !!!
I'll tell you this bonny lad: If you're a spark & you have to ask questions such as this, your name should not be Mat .. it should be Mud !!
Now for Christ's sake .... get somebody who knows what they're doing to do the job for you !!
M
Mynamesmatt
cheers for the help guys! haha, not a lot of point asking questions on this forum i see..
telectrix
Mentor
well, you are asking some pretty basic questions that you should know the answers to if you are about to change a cU.
P
Plonker 3
This is a electricians forum, you are doing electricians work, any one carrying out this sort of job should understand the basic principles. You seem to lack them.
Advice given to Mr DIY doesn't hurt anyone, but this sort of job could lead to a serious situation or even death.
I like many others will try and give as good advice as possible, which I think you will find I did in my first post on this thread. By all means continue asking but also be prepared for hearing things that you may not want to hear.
Reply to Another fuse board change post! in the Electrical Forum area at ElectriciansForums.net
