A
Alextrician
It showing a “noise” sign when live testing sockets for some reason. Sometimes it does it and sometimes it doesn’t just think it’s weird.
Never knew tester could pick up signals from cables
yes I have heard of that before ,it picking up some body sing next door .;)
Yes electrical noise can affect results when using low-current anti-trip test methods, if it displays this symbol you should use the high current test instead as the results may be incorrect.
It’s all in the manual for the tester:
It usually comes up on low current ZS testing when other circuits are drawing a load shared by the same rcd.
Yes it’s very annoying.
dam ,I was just about to post that up .
What? You mean a subtle hint that reading the manual for the tester is a good place to start with finding out what an error message means?
RIP common sense!
Don't be daft, real men don't bother reading instructions first.
Anybody familiar with this sign on a tester.
Alextrician,
Midwest,
